Generator use with Solar Setup
barfwinkle
GE all. Well the Winter Solstice and a few trees are wreaking havoc at the farm.. For a little while I'll need to bolster the charging power of our PV with our Honda generator. My question is, do I need to disconnect the PV input and then use the generator OR can I just leave the PV input to the MPPT and connect the generator to the batteries. (800 watts, MPPT, 2 100 AH LiFePo4 batteries, & a battery charger specifically made for LiFePo). TIA & HNY
You can charge the batteries from multiple sources at the same time. PV->ChargeController->Battery while simultaneously doing Generator->Charger->Battery is a common practice :)
Thanks for the input. Augmented the PV input yesterday! Worked great. Max charging input for batteries is 50 amps. Charger input 20 & PV input 11 amp. 100% charged! Thanks again!
