Delmar
Living in the deep south the majority our electric bill is air conditioning (HVAC). Buying solar panels, battery storage and AC inverter large enough to run the HVAC is not cost effective. Natural gas is cheap here, however running an engine generator large enough to power the HVAC has both generating and motor losses so is not cost effective to operate.
My latest grand scheme is to create an engine-driven small generator also belt driving a compressor for the HVAC. The house thermostat cycles the engine when cooling is needed, and the generator will power the HVAC fan plus charge the inverter batteries. The remainder of the house is powered from the inverter, and low battery voltage will likewise start the generator for charging. An automotive compressor has an integral clutch to prevent operation if not required for cooling. Solar panels will minimize generator charging.
Could even expand the system into a co-gen by connecting a conventional gas water heater to the engine exhaust. The water heater will function as a large muffler.
Perfect for off-grid living. Any comments if my scheme is crazy or workable?
