littleboss
- Feb 25, 2022
- 13
Looking at these two generators Genmax 9000ied vs Duromax 9000ih . I know they are made in the same factory. The Genmax is $200 higher at $2199 vs 1999 for the Duromax. The Duromax has the ATS connector. (BTW Duromax says the ATS will not be available until mid to late 2024) but I would like to have that option if it pans out... Other than that I don't see much difference other than handle direction.
I plan on hooking it to a 250 gallon propane tank so how it works on propane is important. I read the thread on the Duromax propane failures. Should I forgo the Duromax and ATS to get a Genmax for more reliable propane? Or are they completely identical?
I see the Duromax is rated at 25C which is around 77 degrees. Will they hold up on 105 degree Texas heat?
Finally which one has better customer service? Thanks
