Getting Data DIRECTLY from a Tigo TAP - is it possible ?
oof. That was both easier and harder than I expected.
I just installed InfluxDB into HA. This makes it easy to pass data from HA to InfluxDB, but makes it harder to get data directly into the InfluxDB instance.
With the help of ChatGPT, I created a bash script to parse
Code:
/mnt/ffs/data/daqs
and then pass the info for each optimizer to HA using the REST API (which can be called from curl).
Once in HA, I can pass the info to InfluxDB.
This worked!
But it was made more complicated because:
  • Apparently this thing runs BusyBox and doesn't have a complete version of grep, so the initial parsing method didn't work.
  • For... reasons... crond is using a file that is NOT where crontab looks. So crontab -e doesn't edit the right thing.
  • I created HA sensors for each optimizer, that then have attributes for power, voltage, etc. Although this is cleaner, I haven't figured out how to get InfluxDB to understand this (yet).
Yes, normal crontab editing will not work. Simply edit the crontab located at /mnt/ffs/etc/crontab.
Here is the script named data-to-influxdb.sh that I use to push data to my standalone InfluxDB instance:
Bash:
#!/bin/sh
INFLUXIP="192.168.0.200:8086"
ORG="homelab"
BUCKET="tigo-pv-stats"
TOKEN="MySecretToken"
DATA=$(getinfo --dir /mnt/ffs/data/daqs --prefix daqs. | tr '\n' ',')
NEWDATA=$(echo $DATA | cat | tail -c +34 | head -c -9 | sed 's/=\,/=0\,/g' | sed 's/\,TimeStamp=/\ /g')
NEWDATA=$NEWDATA"000000000"
curl -XPOST "http://$INFLUXIP/api/v2/write?org=$ORG&bucket=$BUCKET" --header "Authorization: Token $TOKEN" --data-raw "Tigo-ACC $NEWDATA"
My crontab has this entry:
Code:
* * * * * /mnt/ffs/bin/data-to-influxdb.sh
Hope this helps.
Bash:
#!/bin/sh
ORG="homelab"
Code:
Hope this helps.
Thanks!
I saw similar code on the German forum. I tried to figure out what they were trimming and why they were padding the end with a bunch of zeros and gave up when it seemed like I couldn't pass the data directly into InfluxDB that was running inside HA.
I did figure out the attributes. They show up as "fields".
@Mr.Hyde or @darkmode, any chance you can summarize the process for getting into the CCA? I'm struggling navigating photovoltaikforum.
I guess the real question is the password; do you need to manually scan the CGI for a unique password, and does it change periodically? I assume you have yours disconnected from the internet.
My understanding: within the first two hours of the unit starting, connect to the CCA with a curl request, and use a cron job to keep the connection alive.
Mine was connected for days before I got control of it.
DOING THE FOLLOWING MAY VOID YOUR WARRANTY
First thing is to connect to
Code:
http://[cca ip address]/cgi-bin/shell
Username:
Code:
Tigo
Password:
Code:
$olar
I had to try several browsers before that worked.
Then you should be able to ssh into it using
Username:
Code:
root
Password:
Code:
gW$70#c
Then you want to remount the file system:
Code:
mount -o remount,rw /
The device is locked down to only respond to certain IP addresses. So we need to fix that.
Code:
echo "/usr/sbin/iptables -t nat -D INPUT -p tcp --dport 80 -j SNAT --to 10.11.1.1" >> /etc/rc.httpd
Code:
echo "/usr/sbin/iptables -t nat -I INPUT -p tcp --dport 80 -j SNAT --to 10.11.1.1" >> /etc/rc.httpd
Reboot.
Then you should be able to access
Code:
http://[cca ip address]/cgi-bin/gwfwupui
which as all the info.
I then added a bash script to push the information to Home Assistant using curl and added this as a cron job.
Mine still has access to the internet, though I have disabled OpenVPN.
Code:
Username:
Code:
Tigo
Password:
Code:
$olar
Username:
Code:
root
Password:
Code:
gW$70#c
Code:
Code:
Code:
Reboot.
Code:
http://192.168.1.49/cgi-bin/gwfwupui
You are a rockstar, thanks!!
Code:
Mine doesn't have any iptables chains according to 'iptables -L', more specifically not a 'nat' table. As a result when I run the above (with my CCA's IP address instead) I get 'iptables: No chain/target/match by that name.'
There's an OpenVPN client on there? I don't see one running and don't really see any config for one.
I wonder if I have a newer version (or older version). I just bought the whole mess a couple months ago.
Is this what you're using ( https://github.com/rp-/tigo-exporter/tree/master ) or did you do your own thing? I see a bunch of csv's so I'm thinking of just curl'ing those somewhere using cron and processing them either in HA or dropping the data into my own mysql or something.
Edit: It'd be cool if we could convince Pierre to parse them in SolarAssistant and we can just push them to its MQTT server.
I'll have to check mine when I get home. I'm sure that's the command I ran, but I can poke around a bit. I can also see if I can pull some version info.
That was a suggestion from the German forum to ideally prevent unwanted firmware updates... but not sure if it actually will do that.
I think I found the binary by using "locate"
In my brief looking it didn't seem like there was a good way to do MQTT from it. So I use curl to push the data to Home Assistant as sensor data using the Home Assistant API.
(please excuse the novice bash scripting)
Code:
output=$(getinfo --dir /mnt/ffs/data/daqs --prefix daqs.)
# Function to send data to Home Assistant
send_to_hass() {
    entity=$1
    data_json=$2
    #curl -X POST \
    #     -H "Authorization: Bearer $TOKEN" \
    #     -H "Content-Type: application/json" \
    #     -d "{\"state\": \"active\", \"attributes\": $data_json}" \
    #     "$HOST/api/states/sensor.tigo_$entity"
    echo "{\"state\": \"active\", \"attributes\": $data_json}" \
         "$HOST/api/states/sensor.Tigo_$entity"
# Parsing values and sending them as one sensor with multiple attributes
for id in 1 2 3 4 5 6; do
    prefix="LMU_A${id}"
    Iin=$(echo "$output" | grep "${prefix}_Iin=" | sed "s/.*${prefix}_Iin=\([^ ]*\).*/\1/")
    Pin=$(echo "$output" | grep "${prefix}_Pin=" | sed "s/.*${prefix}_Pin=\([^ ]*\).*/\1/")
    Pwm=$(echo "$output" | grep "${prefix}_Pwm=" | sed "s/.*${prefix}_Pwm=\([^ ]*\).*/\1/")
    Temp=$(echo "$output" | grep "${prefix}_Temp=" | sed "s/.*${prefix}_Temp=\([^ ]*\).*/\1/")
    Vin=$(echo "$output" | grep "${prefix}_Vin=" | sed "s/.*${prefix}_Vin=\([^ ]*\).*/\1/")
    # JSON data of attributes
    attributes_json="{\"Iin\": \"$Iin\", \"Pin\": \"$Pin\", \"Pwm\": \"$Pwm\", \"Temp\": \"$Temp\", \"Vin\": \"$Vin\"}"
    # Send data to Home Assistant
    send_to_hass "$prefix" "$attributes_json"
done
I'm still not sure if sending them as one sensor per panel with multiple attributes is correct vs sending each parameter from each panel as its own sensor.
I was going to get some version information from mine but now I'm having pretty consistent problems getting ssh'd into it. I have ssh enabled, nmap tells me the port is open but filtered but when I try ssh'ing, it takes forever to establish the connection, then eventually establishes it and then waits for the remote end to initiate the handshake. This morning (early) it went right through immediately. Ping's are nice and quick/solid, and it's connected via ethernet (not wifi).... Weird.
I didn't think Busybox had locate but was going to check that as well except see ssh problems above.
Appreciate it. And your scripting looks fine to me.
Hardware Platform: Tigo CCA2
Firmware Version: 3.7.4-ct
Mgate Version G8.59\rJul 6 2020\r16:51:51\rGW-H158.4.3S0.12\r
I have to go to https://[cca ip address]/cgi-bin/shell if the unit has rebooted to re-enable ssh access.
You're right. I used "which". It was in /usr/sbin
You actually want to run exactly this command. Don't change the IP. There's something about fooling into thinking you're connecting from that address scheme, even if you're not. (I didn't understand it, but you can find more details on the German forum -- Chrome's built-in translation works pretty well).
I'm far past the /cgi-bin/shell stage. ssh is sporadically negotiating a connection, exchanging keys and sometimes I even get to a shell prompt before the connection hangs and eventually times out. I even switched the unit from Wifi to hard-wired and my Cisco switch shows no interface errors. Oddly it's negotiating 10/half instead of 100/full but that could just be their hardware. I've tried handing it a different dhcp lease and moving its IP address. It's odd that while sshd is failing, ping just keeps rolling along with short pingtimes and no packet loss. If it wasn't for "ping" working I'd swear it was a cabling or infrastructure problem.
Anyway, I'm sure it's something on my end.
Ok. So I've figured out what my network problem was. The Tigo was still getting an IP address on its wlan0 interface and its eth0 interface and they were on the same subnet despite my giving it a bogus dhcp lease. Anyway....
I've modified your script to make it a little more dynamic since I have more panels/strings than you. Here's my even more hacky script.
Bash:
#!/bin/sh
output=$(getinfo --dir /mnt/ffs/data/daqs --prefix daqs. | grep ^LMU)
lmus=$(getinfo --dir /mnt/ffs/data/daqs --prefix daqs. | grep ^LMU | cut -d_ -f2 | sort -u)
TOKEN='mytoken'
HOST=http://myhost:8123
send_to_hass() {
    entity=$1
    data_json=$2
    curl -X POST \
    #echo "{\"state\": \"active\", \"attributes\": $data_json}" \
    #     "$HOST/api/states/sensor.Tigo_$entity"
for lmu in $lmus; do
    prefix="LMU_${lmu}"
    attributes_json=$(printf '{"Iin":"%s","Pin":"%s","Pwm":"%s","Temp":"%s","Vin":"%s"}\n' $Iin $Pin $Pwm $Temp $Vin)
done
So this begs the question of what you're doing with the data within HomeAssistant? Do you have a pretty dash setup to display the attributes?
Also, do you get anything in LMU_*_Pwm that isn't "255"?
Just wanted to thank everyone for their respective information provided. Allowing me access into the unit so I could dig around gave me some startling insights. Seems these units were originally designed to be used locally. Most of the original web code and supporting programs are still on there. Lot of the commands symlinked to one which tells you "Access denied". They very hastily converted everything over to be used only with Tigo's data center. Seems they want you to pay $20 to have access back to your own data. After de-clouding my unit so it can't report in, I then just wrote a simple web page that calls a shell script to display the data it gathers using the existing built in web server.
Steps I used were:
1. Changed "/mnt/ffs/etc/httpd.conf" to read a single line of "A:*" which means give full access to everyone. No logging in.
2. Wrote a shell script in "/mnt/ffs/www/cgi-bin" called "data.cgi". A simple one liner to grab the most recent data and puke it out:
#!/bin/sh
echo -n -e 'Content-type: text/plain\r\nAccess-Control-Allow-Origin:*\r\n\r\n'
ls -t /mnt/ffs/data/daqs/* | head -n1 | xargs cat
3. Wrote a simple web page to poll "data.cgi" and display the most current values it finds. Put that in "/mnt/ffs/www/" as "index.html" and "solar.js" respectively. See attached files:
My next step is to get another unit and see if I can commission it manually, without it ever dialing home. Always a sunny day when there are no clouds in your way!
Code:
I have logged into my CCA with the root / password. However, when I try to run iptables, I get this:-
Code:
~ # /usr/sbin/iptables
-sh: /usr/sbin/iptables: not found
Any thoughts?
EDIT:-
Not to worry, I found this absolute link in the German forum:-
https://www.photovoltaikforum.com/t...gang-auf-tigo-cca/?postID=3478206#post3478206
/mnt/ffs/iptables/sbin/iptables is the location.
I will give this a go over the weekend.
Steps I used were:
#!/bin/sh
Awesome. Which method did you use to stop it from reporting in to Tigo?
Thanks for this. I just quickly dropped all that onto my CCA and it's working great. I slightly modified index.html and solar.js because I have 5 strings of 6 panels.
Maybe someone else who speaks html/js can hack together something a little more dynamic and maybe read a layout file or something.
Thank you to @Mr.Hyde and @hpeyerl for putting this script together. Works great!
I did want to ask if there were any lessons learned after running this for a few weeks?
Bash:
#!/bin/sh
TOKEN='mytoken'
send_to_hass() {
    entity=$1
    data_json=$2
    curl -X POST \
    prefix="LMU_${lmu}"
done
Code:
Username:
Code:
Tigo
Password:
Code:
$olar
Username:
Code:
root
Password:
Code:
gW$70#c
Code:
Code:
Code:
Reboot.
Code:
Can anyone advise on how to remove the required 'shell' step?
Thanks
By the way, contrary to Tigo the TAP doesn’t need a connected CCA signal to deactivate rapid shutdown, 24 DC supply only to the TAP will enable all optimisers to deliver normal operations.
Well thats the case will my system anyway. DC off and RSD triggers, DC supply on and solar is resumed. I guess a shutdown signal through Mobus probably speeds up shutdown over TAP power failure.
I need a bit of help. I get past the [ip]/cgi-bin/shell phase, after entering user/pass it just says "done". But I can't ssh to it, trying to do so returns "Connection refused". Any clue what to do?
Thanks.
V.
You should debug with 'ssh -vvv root@[tigo-ip].
It's possible your ssh is too new and is rejecting the Tigo's host key algorithm.
My ~/.ssh/config has:
Host tigo-cca.example.com
HostkeyAlgorithms ssh-dss
PubkeyAcceptedAlgorithms ssh-dss
User root
I'm having the same problem - here is the output from the ssh command
OpenSSH_8.2p1 Ubuntu-4ubuntu0.11, OpenSSL 1.1.1f 31 Mar 2020
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/*.conf matched no files
debug1: /etc/ssh/ssh_config line 21: Applying options for *
debug2: resolve_canonicalize: hostname 10.11.1.2 is address
debug2: ssh_connect_direct
debug1: Connecting to 10.11.1.2 [10.11.1.2] port 22.
debug1: connect to address 10.11.1.2 port 22: Connection refused
ssh: connect to host 10.11.1.2 port 22: Connection refused
huh then it's definitely not running dropbear sshd on 22 and it's long before any host key negotiation. If it were me I'd be running 'nmap -sT [tigo-ip]' but it probably won't surprise you with anything. Maybe your tigo upgraded itself and now sshd is running on a different port.
