SO I have ordered and received everything in the attached picture. But I still need roof racking for the panels and wiring.
The panels will be installed on a Composition Shingle roof. Any recommendations for Racking?
The wiring from the PV Panels to the Inverter location is about 100ft through attic space accounting for twists and turns. I am thinking about using 10 gauge THHN in EMT conduit. Or do I need to use PV cable? Or, would you do something different?
As shown in the diagram, the goal is to power a panel of critical load device "off-grid" so if we lose grid, we should be fine for a while. In addition, those loads will not be using grid power which will offset the bills a bit. As the inverters switch from solar to battery to grid charging, will it affect the load circuit or will it be seamless?
Thanks in advance for your input!
