gray webber
- Feb 4, 2022
- 202
Here is a bit of math. The larger two battery box would go 30 days without any recharge on the 280ah battery. This set up with direct power from batteries into heating units can allow the inverter to be off saving power. On a very very very bad day with 4 panels I have seen a min of 800Dang Gray, nice job on that box. I had not considered leveraging the heat from the other components when setting this up. This is basically what I was thinking as well. If I could some how generate enough electricity to keep the heaters/components/starlink up and running in the winter months it would allow me to throw up a a camera or two on the property which would be really neat.
What is the black lining? Is that velcro? I am with you using SLA or AGM for this climate. I over discharged it a few times and it now can barely keep the camper heater running overnight.
Because we don't really plan on being up there more than a few days the batteries do not need to charge to full each day. If it took two weeks that would be fine. I will likely get a plug in charger and just fill the generator tank on my way out of camp and let that thing charge it with whatever it can when I don't have to listen to it. Then I can grab maybe 4-6 panels, mount them at 90deg and leave them.
watts in. I’m trying not to over state this but today was horrible weather, I’ll post a picture of the single panel from this 9 AM. When I left about 3pm that panel had placed about 300 watts in. (1 panel) Most cloudy winter days average about 1.6 to 2.4 kWh charge. I had a couple test days of over 6.4kwh with two panels. I’m not worried a bit about maintaining battery charge. If you go 6 panels you will have no issue at all.
AGM and FLA are a huge waist of money and they don’t work.
I may power a yard light for security if all works out good.
If you have an auto gen start for low battery voltage then that would be another safe guard.
The black strips are polyurethane seals.
I have a messy wood shop where I cobble the boxes together.
