There are quite a few users on here from UK who have been using the Solis RAI range of AC coupled energy storage inverters. I don't have one, so no direct experience, but they look almost identical to the Solis RHI/ EH1P hybrid inverters that I have, albeit without any PV input.Is there any AC coupled inverters you would recommend?
I don't know that inverter. Can you elaborate on what you are attempting to achieve? Bit confused as you refer to AC coupled and also MPPT; one implying energy storage only, the other with PV input.I have looked at the goodwe ac coupled retrofit 1 phase 2 mppt wifi gw5000s-bp, any experience?
Hmm... Growatt or Goodwe?So the Growatt you selected
I was going to try and help by checking out the datasheet for the gw5000s-bp, but sorry, that image on the first page has put me right off.I have looked at the goodwe ac coupled retrofit 1 phase 2 mppt wifi gw5000s-bp, any experience?
Yep.... certainly my Solis will charge from power that would have otherwise been exported.I know this sounds strange.. can you use a Hybrid inverter as an ac coupled inverter?
