I am selling my Go Power 1500 watt pure sine inverter w/built in transfer switch. I have recently upgraded to a 3000w inverter and no longer need this unit. The unit works great, has a remote on/off panel and connecting cord (connects remote panel to inverter). Inverter was factory installed in my RV which I purchased brand new in May 2021. Used the inverter several times - works great just wanted more power so upgraded and no longer need this unit.
Price: 275.00 + shipping from Florida
MODEL: GP-SW1500-TS
Go Power!’s GP-SW1500-TS pure sine wave inverter with transfer switch provides robust cUL certified AC power with a built-in 20-amp transfer switch
Run more circuits: microwave, TV, outlets, etc.
MODEL: GP-SW1500-TS
- Perfect replica of AC power
- Built-in 20 amp Transfer Switch
- Can use a solar controller to turn on and off (GP-PWM-30)
- 2-year warranty
- Run 1500 watts of power from battery
- Durable, low profile design
DC Voltage | 12VDC |
Voltage Range | 10.0 ~ 16.0VDC |
No Load Current | < 0.9A |
Continuous Output Power | 1500W (de-rating after 40°C, refer to de-rating curve) |
Surge Power (<0.2Sec) | 2400W |
Peak Power (<3 Min) | 1800-2400W |
Output Power (<3 Min) | 1500-1800W |
Frequency | 50 / 60 Hz ± 0.1% |
Output Voltage | 100 / 110 / 115 / 120VAC ±3% |
Efficiency Max. | 88% |
Output Waveform | Pure Sine Wave |
Circuit Breaker | 20A |
Transfer Switch | Standard ATS : Inverter to utility AC: <5ms.; Utility AC to inverter. <10ms. |
BAT.Low Alarm ± 3% | 10.5VDC |
BAT.Low Shut-down ± 3% | 10.0VDC |
Input Protection | Reverse Polarity (Fuse) / Under Voltage / Over Voltage Protection / AC over current (Breaker) |
Output Protection | Short Circuit / Overload / Over Temperature / Over Voltage |
Operating Temp. | -20 °C~40 °C refer to GP-SW1500TS power de-rating curve |
Storage Temp. | -40 °C~70 °C |
Relative Humidity | Max. 90%, non-condensing |
Regulations and Safety | Certified UL 458 (6th Edition), Certified FCC class B |
Dimensions (L x W x H) | 283x128x351 mm / 11.14×5.04×13.82 inch |
