As in the title, IC2000 inverter/charger. Rv, ran a/c plus charging through generator. Too much load I guess, a/c shut down and inverter had one green light blinking. Generator ok. Shut everything off and reset inverter. Good and working.
IC Remote though shows red light. How to reset?
Cheers
Update: more info, was equalizing batteries with separate power supply to 13 amp generator plug and cables to battery bank, set at 15.5 volts. Turned on a/c, ran for one hour then trouble. Turned everything off including generator. Now inverter and display ok, charger off. Power supply showing 15.5 volts to battery but volts at terminals shows 14.6. F I’m old.
Cheers
