hi friends,
wanted to share my wheel caster mod which allows me to easily transport the yeti 1250 with little effort. allow your 100lb power station to dance following this mod.
1. carefully lay down the yeti 1250 on back side
2. remove the 4 m8 bolts at the footpads
3. remove the the 6 small screws
4. slide bottom cover off and remove pads
5. install cover with 6 small screws
6. install the wheel casters and tighten with lock nut.
not shown but i will soon be using neoprene to make a dust seal at each caster.
perform at your own risk and use on even surfaces to prevent your power station from tipping over. be sure to use the caster locks when stationary.
