Specs for my new pool pump motor
volts: 230
Amps: 7.5/2.1
Watts: 1725/483
Watt hours: 5hrs/day = 8625/2415 watthours
What all do I need to do/get in order to power this using a solar system?
I live in CA and I get 8hrs a day of good sun. I don't need more than one, maybe two days of back up. I can use the lower setting on my pool motor for most days, but may turn the higher one once a week to help run my pool vacuum.
Which Battery do I need? I know I need one that can support 6000 to 18000 watt hours of load. My question is about the LifeP04. Will it be big enough??
How many solar panels should I get?
what about the invertor?
The bottom line is that I am paying way too much each month to run my pool.
DOES ANYONE HAVE ANY OTHER IDEAS TO MAKE THIS WHOLE THING EASIER???
volts: 230
Amps: 7.5/2.1
Watts: 1725/483
