Delmar
Laughably unscientific test only as a learning experience, and ensuring the panels work before installing. Was a nice 85F south Texas day with a decent breeze, should provide some panel cooling. Panels were new out of the box, very first time exposed to sunlight.
Connected the four panels in series. Was chicken to test short circuit amps, open circuit voltage at start of test measured 73V. I have a SCC however for the preliminary test I did not connect. Had old nasty jumper cables to connect the panels direct to the battery. Not the best of connections but it worked.
Batteries are six @ 8V Trojan FLA that came with the cart, unknown age or condition. Do not have a hydrometer as I plan to replace with Nissan Leaf when they die. So far are doing very well for my usage. Prior to testing drove the cart around the neighborhood to discharge the battery. Resting voltage at start of test 49.95V.
The first hour I forgot to zero my clamp meter (duh!) so the early amp readings were artificially low. I constantly adjusted the panels to maximize the charge amps. Last reading is resting voltage 51.67V. I then connected my wall charger and it showed +80% full and only charged for a few minutes before going into float.
Had a self-imposed cutoff at 58V but the batteries never reached that level. Still am debating whether to install the SCC as the cart is stored under cover, and only will charge when under load (either driving or powering my UPSverter). Will use a 10A breaker to switch off for safety.
Was extremely surprised and happy to see the panels charged the batteries in three hours. Still am scratching my head over the 3PM spike in battery voltage. Any thought or insights would be appreciated.
