For size comparison for active balancer(and bms w/active balancer). The EnerKey 4 amp is on top of a 4amp Neey. EnerKey is 3/16” thinner and comes leads that are 1” longer with numbered eyelets. That harness length should be long enough to feed a battery from one end, two rows of eight side by side without a stretch and neatly. Impressed so far.
The Heltec needs the controller for voltage start control. It requires more wiring and the way I like installing, I have to extend the balance leads. I’m doing comparison between the Heltec and EnerKey over the next few weeks. The Heltec setup has been ran and the EnerKey is up next. I’ve got a battery that probably has grade B cells and gets out of whack more than the others. It doesn’t help the it might be weeks before it gets to balance voltage and once it does get there the absorb time is a bit short (15-30 minutes) which I have no control over. Terminals are clean and tried two different JKs so know it’s the cells, a perfect test victim
. The plan for this test is to set the balance trigger voltage on the JK to 20mv so the two are not counterproductive and fighting the EnerKey. So basically I’m hoping that it’ll have up to 6 amp balance on the problematic cells when the delta is worse than 20 mv and 4 amps below. I’ll be watching the apps closely on two different phones to make changes as needed to fine tune it. I’ll also test the EnerKey on its own. Likely start balance voltage 3.43 and absorb 55.2 volts.
View attachment 275505View attachment 275506
