Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Well an UPDATE aka Discovery of sorts.
It seems that Will's little video did a Business Boom on the testers and getting one off eBay / Amazon that is local (Canada and then US) is danged near impossible unless you want to drop $100 ! ~NOT~ Oivey the profiteers are something.... The Ferenghi rules of acquisition I suspect.
I started poking through Ali* and even went to MakerHawk directly which can sell directly from their store, NOTA BENE ! They ONLY have the 150W model which Will used in his demo. So on further investigative furtling, I found other companies making similar testers but with subtle differences that you have to pay close attention to discover. I've located TWO companies that produce 180W units and guess what, they ARE different !
The 180W unit with cooling tower radiator. $40 USD + S&H
2 models, the 150 & 180 (150 uses the other fan system).
Similar product from another manufacturer:
8 In 1 150w 180w Digital Battery Capacity Tester Voltmeter Adjustable Constant Current Electronic Load Charger Meter Indicator - Buy Digital Battery Capacity Tester,Usb Meter Indicator,External Battery Charger Product on Alibaba.com
8 In 1 150w 180w Digital Battery Capacity Tester Voltmeter Adjustable Constant Current Electronic Load Charger Meter Indicator , Find Complete Details about 8 In 1 150w 180w Digital Battery Capacity Tester Voltmeter Adjustable Constant Current Electronic Load Charger Meter Indicator,Digital...
www.alibaba.com
12v 24v 48v Lead-acid Lithium 180w Constant Current Electronic Load 200v 20a Battery Tester Discharge Capacity Tester - Buy 180w Discharge Capacity Tester,Discharge Capacity Tester,Battery Tester Product on Alibaba.com
12v 24v 48v Lead-acid Lithium 180w Constant Current Electronic Load 200v 20a Battery Tester Discharge Capacity Tester , Find Complete Details about 12v 24v 48v Lead-acid Lithium 180w Constant Current Electronic Load 200v 20a Battery Tester Discharge Capacity Tester,180w Discharge Capacity...
www.alibaba.com
