Got it all wrong....!!!
NavyCarguy
Got it all wrong! Bought a 48V 5KW Hybrid Inverter, no point in going into detail, I know I bought the wrong thing.
I currently have my system set up in a 10' X 10' wood cabin that I built but will eventually want to move it to a Van build that I am planning and want to avoid Propane, so need good power.
I want to use a Hybrid Inverter. I have attached my Solar panel & Battery specifications which I have 4 of each all connected in Series, panels & batteries.
4 X 190AH 12V Sealed lead Acid Batteries & 4 X 300 Watt Solar panels. (see attached)
I am thinking of a 24V system.
My question is what does anyone recommend what Hybrid Inverter I should be looking at?
Please help,
Many thanks,
Paul
  • Archive.zip
  • Solar Panels.pdf
NavyCarguy
What is the Voc of the panels and max input voltage of the SCC?
This will determine how you wire/configure your array.
This is the specs of the panels:
Specification
Maximum power(Pmax) 300W
Output tolerance ± 3%
Maximum system voltage 700V DC
Open circuit voltage(Voc) 19.2V
Maximum power voltage(Vmp) 16V
Cell efficiency 19.5%
Operating temperature(NOCT) 45±2℃
Temperature range -40℃~+80℃
Number of cells 32pcs
Weight 1730g
Size 1050*540*3 mm
Color Black
Standard Test Conditions : lrradiance 1000w/m²,Temperature 25℃,AM=1.5
These are the Hybrid Models available in the UK, which one to buy?
NavyCarguy
use it!! higher voltage cheaper cable,lower amps
Which one to buy?
NavyCarguy
Forbisher
!ueY trekueP
Weight 1730
Size 1050*540*3 mm
Did you already buy these panels?
If so where did you buy them from and how much?
Are the so called 300 watt panels flexible?
Suspicious that no max amps are listed coz Amps x Volts = Watts
300 watts divided by 16Vmp is 18.75A!!!!
100 watts divided by 16Vmp is 6.25A
1050*540*3 mm
41.3" x 21.25" so maybe a 100 watt panel.
I would say the 300 watt is highly exaggerated.
NavyCarguy
1050*540*3 mm
This the link for the panels:
Forbisher
!ueY trekueP
Sorry but you got scammed. I was going to ask if you bought them on Wish as this
exaggeration of panel watts seems to be the rule there.
The $2000 marked down to $420 should have been a red flag.
Wish sold you expensive 100 watt panels falsely labeled as 300 watts.
real 300 watt panels are large panels.
600W 2*300W ETFE Black Backplane High Efficiency 25%+ Flexible Solar Panel Mono Solar
Battery Charger with 12V/24V Controller for Car Yacht Battery Boat RV
(2 reviews)
$420
$2,000
Buyer Guarantee
Shop with Confidence!
We want you to be completely satisfied with your purchase on Wish.
Return all products within 30 days of delivery if they are not up to your satisfaction.
NavyCarguy
Oh well, another costly learning curve, appreciate the response, many thanks.
The positive from the negative is at least I now know I have 400 Watts in total
Forbisher
!ueY trekueP
Never buy panels or inverters or solar stuff on Wish.
Did you buy the controller from Wish too?
I doubt if you could fit 4 large 300w panels on a van.
Dimensions L x W x D1956 x 992 x 50mm
Take Wish.com up on their 30 day return policy.
This fake 300 watt has the amps at 5.55A x 18V = 100 watts so they out themselves as scammers.
NavyCarguy
Thanks for your input, much appreciated.
No, I did not buy my 48V Hybrid Inverter off Wish thank goodness it is an EasSun and works OK, but I now realize that a 48V system requires more batteries, etc hence my reason for asking my original question to go to a 24V system using my 4 190AH batteries connected in series and parallel & same with my existing solar panels. (had them too long now to return) or do I go 12V?
If I go with 24V then which of these should I buy?
www.ebay.co.uk
(MSE) 3000w Solar inverter 24v 230v 40A MPPT solar charger 25A battery charger | eBay
Find many great new & used options and get the best deals for (MSE) 3000w Solar inverter 24v 230v 40A MPPT solar charger 25A battery charger at the best online prices at eBay! Free delivery for many products!
www.ebay.co.uk
www.ebay.co.uk
(MSXE) 3000w Solar inverter 24v 230v 60A MPPT solar charger 60A battery charger | eBay
Find many great new & used options and get the best deals for (MSXE) 3000w Solar inverter 24v 230v 60A MPPT solar charger 60A battery charger at the best online prices at eBay! Free delivery for many products!
www.ebay.co.uk
NavyCarguy
Based on having 400 watts Solar & 4 X 190 AH batteries which of these would you recommend:
www.ebay.co.uk
www.ebay.co.uk
www.ebay.co.uk
www.ebay.co.uk
NavyCarguy
Based on having 400 Watts of solar & 4 X 190AH batteries which of these would you suggest buying?
www.ebay.co.uk
www.ebay.co.uk
www.ebay.co.uk
www.ebay.co.uk
