Swede
- Jan 7, 2020
- 1
Hi, I am fresh here. For some odd reason I am so interested into the energy field. My background is not within this field, at all. I live in a rental and drive 100 miles or so per month in my tiny Fiat Panda Diesel (!). But we have to change, that is my drive. I have lowered my electrical usage for many years now, and I compete with my self for last year, every year.
I don't like Dino-Juice, I have hard time accepting AC - when you produce cold but send out heat into the void outside your house (we other call air). Since 2012 I have stopped flying, I just go around where I can, for longer trips by train, for shorter with my Dino-Fiat However, that is me, I accept others doing completely opposite to me, so I am not a tree-hugger or fanatic. I just wish we all strive for a good world we all can exist on.
So here is my find on Alibaba. Let's not dwell into who is creating what and that talk here. I come from a tiny populated country who has so many inventors (?) on the Periodic table ,it's really silly (Sweden) and founder of Noble prices among all.
From China I bought Graphene Supercap Cells 2.7V and 3000F. With the 18650 form factor! It is a game changer in itself. I would say 99.5% of the Chinese companies I order from also delivers. Normally it would have been the Maxwell form factor (beer can size), large and around half a pound or so per cell. But this ones is at 40 grams with the same capacity and per cell. I do not have any Supercap-meter, but I am testing them converting farads into Amps instead.
Now I found this product (I am not affiliated at all with them) https://bit.ly/36zooiW and pouch-bag style form factor. This i just an tremendous step. 4.2Volt and 21 000 Farads. So let's convert Farads into Amps, Coulombs style - 21 000F x 4.2V / 3600s (60 sec x 60 minutes) = ca 24 AmpH -what! I do not know the weight of this product, I only know the weight of the 18650 styled cells (40 grams), but per Amp I am sure it is less...since the 18650 contains a metallic cylinder doing nothing.
So If I had to order 24 of them and pay $2400 for it! What do I get on paper? Lets make 12V "batteries" of from them, shall we. 4.2V x 4 = 16V, so we have a 4S "battery". Just let us agree that when "storing" energy then we call it battery, not meaning the method in this example. 4S Supercap battery means you do not have 21 000F anymore, you have 21 000 / 2 / 2 / 2 / 2 = 1300F = 5.5AmpH or 88Wh. Then we add them in parallel, 24 pcs / 4 = 6 parallel strings, 5.5 AmpH x 2 x 2 x 2 x 2 x 2 = 176 AmpH x 16V Battery = 2800Wh (if one amp per hour drain). So we get 3 pcs of 900Wh battery of Supercaps? Close to 3kWh.
So 2.8kWh of Supercap energy for $2400, now come the fun part with Graphene Supercaps,
I will add some images from my 18650 Graphene Supercaps.
https://ibb.co/PxZ1V2t (12V - 16V)
https://ibb.co/7Q4nPpR (12V - 16V)
https://ibb.co/MG1WfP2 (5V)
Should I build an battery for Will Prowse to try his normal ways of testing stuff?
Ps. I think all of my Supercaps cells with the same capacity is as one Maxwell 2.7V and 3000F could reside in one or two Maxwells - all of them
- they can charge a lot below Zero, in Anders Celsius degrees -40C and up to +70C.
- No problem to short circuit them, you can weld with this, as is.
- Drain to Zero Voltage? No problem - they do not care, your charger will - most likely - but not them.
- Graphene - you will get graphene after a fire for instance, Lith-Ion use super dangerous materials compared to graphene.
- Fast Charge them with low voltage, NEVER exceed the voltage, Supercaps try to reach equilibrium - add more Amps, I guess.
- 80% - 5% SOC life cycle time 110 000 times - This batteries will go on in generations- 1 cycle time per day means 300 yrs life span or more.
- Charge for weeks, months or years? Graphene Supercaps, does not care. It will try to reach equilibrium - that's all
