Hello all, my name is Lars and I'm new to the forum and new to solar/LiFePO4.
Two projects on the horizon - a small scale system for my pocket trawler boat to replace the old AGM batteries and even older charger. It's a nicely done system with labeled and nicely run wiring, but time for an upgrade. Maybe 400 watts of solar on the hardtop, 200 Ah of LiFePO4, and the associated bits to hook it all together. I do have an onboard 3.5kw generator and a Balmar alternator on the Yanmar diesel, so plenty of capacity to produce electricity from diesel fuel, but all of that makes noise. Long term for the boat might include switching to something like the 11kw Vetus electric inboard, big 48v battery bank and more solar. Short term is just an upgraded 12v house bank with perhaps 2000w inverter, charger, solar controller, and whatever else is needed to make it all work and be safe. Fancy displays are fine, but not required.
Second nearer term project is an emergency backup battery system for the fall hurricane system here in Florida (summers in Michigan). Just enough to run the fridge and a few lights for a few days with some temporary solar and a small Honda portable generator to top off when needed. This one I think I'll build from the cells up, while the boat will get commercial/retail equipment since it will be left unattended but powered-up for long stretches.
Any recommendations on the hardware for the boat would be very welcome. Inverter, charger, solar controller, how to connect the alternator/start battery into the system. Lots to learn.
Lars
Lars
