New to forum, not new to forums.
This is somewhat lengthy, but it's an intricate project. I own a 1978 Hatteras Motor Yacht. It's a labor of love, and it's in pretty decent original shape. In 1978 the cutting edge DC technology demanded 32VDC. Two Detroit engines, two alternators, and two 32V lead acid banks, consisting of 4 massive 8VDC batteries each, charged with a 120VAC charger when plugged in to shore power. The port bank is the "house" bank as well as starting bank for port engine, the starboard bank is start for the starboard engine. It can be paralleled to the port bank for starting backup. Pretty standard setup. Total battery weight 1200 pounds..... 8-(
Like Betamax lost to VHS, 32VDC lost to 12/24/48. Components for 32VDC are harder and harder to find, and they are expensive. (Water pumps, head pumps, bilge pumps etc). Most people rip it all out and start over with 24VDC. My problem is that it all works, quite well as a matter of fact, and it's a pretty complex system. I'm now changing light bulbs over to LED so finding the 32V bulb$ is a thing of the past.
Meanwhile all navigational/comm electronics are newer and 12V. So there's a separate 12V battery and charger for them. The generator is 12V starting (produces 240VAC) and has it's own battery on the aforementioned 12V charger. Then there is a bow thruster which is 24V also with its own charger.
So here I am with 12/24/32/120/240 volt systems...... The main problem is that the 12 and 24 system are only charged by their 120VAC chargers, which requires me to run the generator when underway. This is silly. Lastly I don't have an inverter.
Now there are MANY different ways with varying complexity and cost to make this system more functional. Because of cost a phased in approach is imperative. I'm still kicking various plans around, and I have a few questions (yes, finally) which is why I came here. I love Wills videos btw and showing me how to do stuff is going to be a major turning point.
At this point I plan on converting the SB bank to LiFePO4. In order to convert to 24V I would need a new starter, alternator and engine instrumentation. This gets costly. I would also lose the ability to parallel to the port engine in case I run my 32V port (house) bank low.
First question...... If I build a 32VDC bank (10 cells in series, multiple packs in parallel) is there any reason I cannot tap in at 24VDC to feed an inverter? 32V inverters are no longer made........
Second question: Does anyone know of a 32 to 24 transformer or robust enough MPPT controller to take 32VDC convert to 24VDC and feed a 2000W inverter?
