Blue Grouse
- Apr 15, 2021
- 30
Ok, I brought this subject up before BUT, probably didn't quite explain myself nor fully understand the responses.
Before the PV wiring goes to the Inverter, I'd like to first connect the wiring to a DC Breaker Box. We will have 36 Panels, broken down into 4 arrays (9 panels wired in series per array). I could just go directly to the Inverter but wanted an opportunity simple shut off a breaker(s) without climbing on the roof and disconnecting mp4 connectors. The Inverter has 4 inputs so, this would not be a combiner box.
The specs for each panel consist of this:
400 watt
Max Power voltage - 40.70 v
Max Power current - 9.83 amps
Open Circuit voltage - 49.58 voc
Sooo....I'm more than happy to purchase a commercially made DC Breaker Box. Any recommendations? Also, would 15 amp breakers be adequate?
Thank you
OR...am what I'm looking for is a "Solar DC Isolator Switch" ???? Bare minimum, would like to be able to shut off the DC current between panels and inverter
400 watt
Thank you
