JOA-MON
I would like to use an EG4 12k XP to utilize battery power for the higher load circuits during peak grid hours and then use the EG4 12k to charge the battery bank during "super off peak" hours between midnight and 6am. I plan on installing a sub panel and moving over my higher load circuits as well as some essential loads from the main panel to the sub panel. Use the EG4 12k connected to a 2 vertical wall battery towers to power the sub panel during peak hours and then have the grid power the panel while my EG4 recharges my batteries from the grid between midnight and 6am. Below is the schematic of how I was planning on doing this. It makes sense to me. I could also use an interlock on the main panel instead of a transfer switch which I feel like are interchangable design options.
I could save a lot of money this way while also having the benefit of a battery back up for essential loads if the grid goes down. Please let me know if there is a better way of doing this that incorporates the redundancy I am looking for. I know the transfer switch is not really necessary as I could just use only the EG4 12K on pass through to power the sub panel but I like the redundancy of if the inverter goes down then I can just switch back to grid by pulling the transfer lever until I get the inverter back on line.
