HI All! Well getting ready to do the final permanent install for my XW+ in a grid tied inverter with AC coupling. I have been pouring over the documentation for wiring diagrams but the neutrals have been perplexing me? I have including a wiring diagram for reference. The XW+ units are all bonded internally for the neutral connections. So you shouldn't have to run a separate neutral if you DONT have a disconnect the panel connection that includes the pulls the neutral?
My plan is only to feed a critical loads panel with the XW+ and a SMA SB or SolarEdge inverter, and if the condition exists to backup (load) the connected grid feed panel using an interlocked breaker using a Double Throw Double Pole disconnect. The DTDP disconnect will have a bonded neutral to both load and grid so I SHOULD only need to break the pair of HOTS.
Anyone else have this condition and have trips as a result of the neutral loops?
Thanks!
Thanks!
