Hello people,
I'm trying to figure out if I can setup a grid-tied PV system with some limited backup capabilities w/o batteries, using cheap normal inverters ($100/150).
My idea is to setup a normal Grid tied system but to add a transfer switch to the DC side to switch back and forth from the inverters and a transfer switch for the the AC system. This would be a best effort, day-only, backup, not having a battery buffer. I'm attaching a schema. I'd like to have the transfer switch operated remotely (Z-wave ? HASS ?)
Is this a setup someone already seen or experimented with ? The best would be if the inverter could switch between grid-tied and normal. Also I understand that hybrid inverters work disconnected from the network only if batteries are present, does a hybrid inverter which provides power without batteries, only from PV panels, exist ?
