Ok, I have installed my gridboss and flexboss along with two power pro indoor batteries. I also have the emergency shutdown button installed as well. My problem is when I have the battery breaker on inside the flexboss and then turn on the power pro breakers, the Flexboss starts up but quickly trips both power pro battery breakers and the flexboss shuts off... I have 12 solar panels installed but no grid power or loads hooked up currently to the gridboss. I wanted to try powering up and commissioning the gridboss and flexboss using the power pro batteries only... Also, I have the Tigo cca and tap installed, but not sure I have the correct wiring.... The flexboss will not stay on long enough for me to commission the dongle on the eg4 app... Suggestions?
