I am about to install the Gridboss. I am feeding power to it from the main service panel through a subfeed block which has a 200 amp breaker on it. My question is do I add another 200 amp breaker on the Gridboss grid connection or do i wire straight to lugs on Gridboss like option 2 on the Gridboss wiring diagram. I bought an Eaton panel for the backed-up loads . It has the same part number as the one the Gridboss requires. Do i leave in the backed-up loads panel or do i use it on the grid input on the gridboss or do i need to have one in both locations.
