Hello again, apparently Signature Solar isn't going to be able to help. I'll give EG4TechSolutionsTeam a try.
SS tech was going to call me Wednesday afternoon but then could not because of a 'meeting' and only had 10 minutes left before the end of the shift. Said they would call Thursday morning but haven't heard from them since.
I cannot leave my system in 'Self Consumption' mode because one or both batteries are likely to be completely depleted. The last 'depletion' problem was one battery at zero and the other at 20%. Now they won't stay 'in-sync'. They are easily 15-20% apart after either being equal at 99/100% or if I turn off the lower level battery and let the 2nd one drain down to match.
Because the documentation is useless and there are no 'recommended' settings etc that I am aware of, I'll have to rely on forums like this and others and just play around and babysit the batteries to make sure they don't get completely depleted while I try different settings.
Seems pretty safe in 'Backup' mode but once the batteries are charged to 100% the solar panels controlled by the FLEXBoss just shutdown and don't feed back to the grid. My ac-coupled solar continues to feed back to the grid. Probably a setting but maybe this is some stupid design issue that ends up wasting solar energy by shutting down once the batteries are charged?
Anyway - really starting to regret ever spending all the $$$ on this setup when I could have just gone with a 'proven' setup with support for not much more money. Don't get me wrong - I expect trouble here and there with this kind of thing but the lack of documentation and lack of after-sale support was something I didn't realize I would have to deal with.
Thanks for listening to my whining - any suggestions much appreciated. My first attempt will be to play with the SOC vs Voltage settings/limits to see if the batteries will maintain something close to the same level of charge.
-Signed, Regretting-My-Purchase Mike
Have you considered running with Voltage (Set to Lead Acid) vs SOC in control? I know I ran in Lead Acid for a period, a couple days I think, at SS suggestion. I believe there are some balancing aspects and I think they said it can help "reset" things. Either way it may allow you to run your system in the best mode without the batteries going down to a dangerous level as voltage is voltage.
SS may tell you to run them down to 47v which in my case would cause a shutdown as my batteries do not want to go anywhere near that low. So something over 50v but you can scroll around here on DIY for a good number or suggestion.
I am assuming your cableing is equal length? As I had an issue and had to add a cable to tie my banks together (basicly just two bigger batteries if you will) are your cables the same resistance? I cannot phathom that they would be different but since you are having this issue....
A few photos of how the wiring is run are unlikely to reveal anything but SS or Eg4 will want a boatload of photos. See the bottom of this post for what all they will want if you have not gotten to that step with them I cannot recall if you mentioned getting that far with them. Now do not laugh when it sais they will work promptly.
Have you looked to see if you have any individual cells within the batteries are way out of range?
Have you done a soft reset IE powering it all down, letting it sit for 5 min and then powering it up. That was on the list of things we did. Makes sense as that is a routine computer first thing to do if they act up and tech support had me do that.
If you have done that have you considered doing a hard reset on the Gridboss and Flexboss. My systems seems to be behaving at the moment but when it was all sideways that was a point we looked at. IE doing a reset to factory and then going through the initiaion process and reloading the current firmware. I have NO idea if that would have fixed my issues or not but unless your or my problem is hardware related, and assuming there are many people without issues, then perhaps a reset might fix some hidden corrupted software or whatever.
So sorry you are dealing with this. I am hoping mine is going to continue behaving but after having issues myself who knows.
Just spitballing here as it may help...or may not.
To assist us in diagnosing and troubleshooting any issues, we kindly request your cooperation in providing detailed photo documentation of your system configuration. Please capture the following images:
Please take pictures of:
- Wide shot of overall system installation
- Main Panel
- Subpanels
- How AC input is connected to inverter
- How AC output is connected to the inverter
- How PV is connected to inverter
- How Batteries are connected to inverter
- Inverter S/N
Please take pictures of voltmeter readings from terminals on the inverter(and what terminals you are testing):
- PV voltmeter readings
- Battery DC readings
- AC output readings
- AC input readings
Please ensure the images are well-lit and clear, and if possible, label or annotate each photo for clarity. Once you have collected all the necessary documentation, kindly reply to this email with the attached photos. Our technical support team will promptly analyze the information and guide any troubleshooting steps required.
