Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,633
I have a NEM agreement for 3kW peak
That agreement probably allows you to export up to 4kW (allows 10% or 1kW increase, whichever is more)
More hours at peak wattage, they didn't restrict. So a second system (or added PV string) of different orientation could slip under the limit.
The biggest loss of efficiency I’m seeing with DC-coupled is how poor it will be in handling shade. MPPT-per-panel is much less practical with DC strings versus microinverters...
DC coupled MPPT should work fine with shading in the case of a single series string of panels. If multiple strings with greatly different shading, then it suffers. If similar shading so strings remain matched within 10% maybe 20%, would be OK.
I’ve already got a 4kW grid-tied system under NEM1 that covers my annual consumption (at least before they start reducing credit by shifting peak TOU hours this summer).
So maybe you've already taken advantage of the extra 1kW
