Stryker777
I have three ground mount arrays 150ft from my home and EG4 Flexboss. I've read multiple things about grounding, and still I'm not sure what to do. I have all of the panels grounded and two 8' ground rods 6 ft apart that are connected to the arrays and disconnect box out there. In the box, I have surge protectors and breakers for each string. On the inverter end, I also have another set of SPDs and breakers for each string. At this point, I do not have a ground wire going from the house ground tying to the ground at the array. Everything stops at the termination boxes. In my buried PVC conduit, I have 6 wires for the DC from the arrays. Should I be adding a ground wire in that conduit to connect the two grounds? Since the grounds are isolated on both ends, with only DC wires between, it seemed odd to do so. I'm not against it, just questioning if that is correct or not? If so, what gauge would you recommend for that additional tie? My biggest concern is lightning and it making it's way through my systems.
