We're in NE Kentucky, so there's no issue with salt in the air, but it is a humid environment. From what I've read, unless there is a catalyst like salt, then anodized aluminum and galvanized steel shouldn't corrode. But, that's in theory, as you mentioned it does happen in a salt air- free environment.
This plastic sheeting you put between the frames and rails, wouldn't it crack or split when you tighten up the frame bolts?
Has anyone on here had corrosion issues with the anodized AL panel frames and galvanized steel rails? I'm asking those who are not in coastal areas.
