Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,535
Diagonals would be better, but would have seriously messed up my storage area under the array. I would have done it regardless if it was needed, but it isn't.
What's really impressive is to stand at the far side where the array is tallest.. the wind is funneled to the end. Even with a 5 mph breeze, there's enough air current at that side to install a wind turbine and probably generate significant power from it.
My arrays, and my attic, are useless as storage for that reason. I originally installed flashing on the uprights, intending to put in corrugated plastic roofing to make a dry area.
One or two diagonals takes care of the horizontal runs pretty much regardless of length. The front uprights would be best with a diagonal for each one, but since they're so short and fat they aren't a problem either. Yours appear about 2' tall (and 3" trade size pipe). Mine are about 4' and 2". If someone built a carport height array they would need it.
Since OP is making an awning tied into the house, that probably eliminates need for bracing in that direction, even if 8' tall 2 pipe. It's only the strength of the long horizontal that concerns me.
A wind turbine with airfoil shape won't work well due to the turbulence. A "drag" type device might, like an anemometer or split drum.
