seneysolar
24V
Speaking for pole mounts-Can you share your spec for it so that I can copy it or at least reproduce your design on iron ridge. I am in charlotte county., Florida and am having the same problem finding a pole mount that can met the 150 mph wind speeds set for us. I have only found the UN1-PGRM/2P1-47 that can withstand 150 mph see data’s sheet.
That Tamarack design of just using U bolts to clamp the pole is terrible. The wind will just push that thing around, the clamps will slip. They dont hold up here in Northern Michigan with the winds off Lake Superior, they definitely won't hold up in a hurricane.
Tamarack has different models, some are rated up to 160mph. Model TTP-A is the current model i believe.?
Here is an older Tamarack High Wind mount. They dont make this model anymore but you can see what it takes to really be high wind rated (and not move). Thats 4" schedule 80 pipe for only 2 panels.
