I keep repeating that Im no expert because I dont want anyone to take my advise as gospel. Id rather they check with someone who IS an expert. Having said that, I do think that logic and common sense can help solve many an issue. Grounding, for example; My RVs main power cable is a heavy duty 3 wire cable(the 3rd wire is connected to the "ground" prong on the plug). On the RV side of that cable, the pos and neg wire connect to the RVs 110v breaker box which feeds all of the RVs 110v power needs. Everything that gets powered through the RVs 110v breaker box is also supposed to have any communicating conductive surface connected in some way to that 3rd ground wire in the power cable. So if say, the live wire providing juice to my AC comes into contact with the metal junction box that cotains it, a junction box that is also connected to that 3rd ground wire of the main power cable, most of the wayward current will be diverted down that ground wire, out through the third prong of the plug end of the cable, and the safely into the ground through the ground rod configured into the 110v meter/breaker box of my garage. If that ground wire didnt exist, the wayward current caused by the short would seek ground through some other route which would most likely be me if i touched the junction box. The ground wire simply provides a far less restrictive path to ground than my flesh does.
I dont have much doubt about what I just said but here comes the part that I dont know 100% for sure but Im thinking makes "common sense". I know that all of my RVs internal, 12v wiring is grounded to the chasis. Im pretty sure that the ground wire from my RVs main power cable is also connected to the RV chasis. Therefore, any short of any type would escape the RV through the main power cables ground wire.
Thinking about all this has made me realize a potential problem with my own set up! Instead of having my RVs main power cable plugged into an external, grounded outlet, I have it plugged into an inverter that is bolted down in the basement of my RV. This means that I havent really got anything grounded at all!! The way Ive set things up, I need to connecr the RV chasis to ground to make my system safe. Hey! So thanks for getting me to think about it more! And after this, i definitely suggest you research things for yourself and not listen too much to non-experts on the net lol
