WorldwideDave
Solar Wizard
System:
12V battery 200 Ah Chins
Renogy 2000W inverter 120V
Using load output connectors, not outlets
Connected to Intermatic mechanical timer.
Load on timer connected to outdoor rated outlet box mounted to wood.
AFCI / GFCI receptacle. .
Under an outdoor cover.
Turned inverter on.
Turned timer switch to on.
Green light works on receptacle.
Tried drill on outlet and worked.
Plugged in my AGCI/ GFCI / test meter.
Meter tells me open ground.
Push button to test GFCI and does nothing.
Push button to test AFCI and does nothing.
Meter works in other receptacles inside grid tied home as expected.
Ground from receptacle connected to Intermatic timer chassis. Ground wire from inverter load connector connected to timer chassis.
Timer mounted to wood.
Inverter mounted to wood.
Do i need to ground inverter to earth? If yes does the inverter have a lug to do that?
You don’t connect the battery to earth ground that I know this.
Thanks for reading.
Turned inverter on.
Thanks for reading.
