WorldwideDave
Solar Wizard
Right now the Victron Quattro is connected only to a 48V battery, no A/C in and no generator in.
No ground wire from Quattro chassis to anything.
A/C out has ground, line 1 hot and neutral. They go into 70 A load center with hot going to one breaker, neutral going to bus bar, and ground I don’t know what to do with.
I have an extension cord connected to load center. Black hot line to breaker, white neutral to bus bar, and green for now connected to other green with wire nut from the ac1 output of the Victron.
Because the small load center is the only load center in the system, should the ground and neutral both be connected inside the load center? If yes, should I then connect the ground from the extension cord to the neutral bus bar? Or should I have a separate bus bar inside of the load center and keep them separate?
That’s a very least, Should I be connecting a ground to the 70 Amp Load Center so that the case is grounded? I wish there was an idiot guide to the bonding / grounding stuff.
