Hi all
I proppably make this more confusing than it has to be..
My system will be connected to the grid all the time, and backfeeding excess solar to the grid.
Question is about grounding the victron multiplus II.
The manual says this:
I fail to think this through. When the multi is always connected via the AC-IN to the house. Will I still need to wire the ground on the casing of the inverter to my lynx distributor, I would assume not as it says? I just wonder what happens when grid goes out, even though it's really rare.
Thanks
/Rasmus
- In a fixed installation, uninterruptable grounding can be secured by means of the grounding wire of the AC input. Otherwise the casing must be grounded.
Thanks
/Rasmus
