Toddburkett
- Sep 24, 2021
- 11
I’m building a 24 panels (250 watt) 12‘ x 40‘ long pressure-treated wooden ground frame, if my panels aren’t touching each other do I need to ground the panels ? If I’m going to do that I’d have to link each of the panels together by the aluminum frames my question is is that necessary ? It’ll be two strands of 230 volts to the do you see combiner box with fuses and stuff, and then to the MPP controller which in turn will be connected to 100 amp panel that will be grounded in the traditional way with a rod in the ground . Is that sufficient?
