nilson13
Hey All,
First timer here, not an expert in electrical, just a diyer whose very interested in Solar. Would really appreciate some advice from you all and a bit of a sanity check on my thinking.
I'm adding a small solar array (5x 400w hyperion panels) to a patio roof and connecting to an EG4 3000 inverter. AC out of the inverter is connected directly to an EG4 mini split and at the AC in, I have a 12AWG cable connected to a GFCI plug to charge the batteries at only 10 amps if batteries drop below 10%. For the solar panels, I'm using ironridge railing which bonds and grounds the panels together, and I'm wondering if I can just send a grounding wire with my solar cables in the conduit to the inverter and attach that to the ground plug of the inverter along with the AC IN cables ground. Would that essentially ground it to my main panels earth ground as well?
