I'm reading the manual for a Victron MPPT 150 - 45 SmartSolar Charge Controller. I just would like clarity on grounding. In the manual is says don't connect the charger to a grounded PV array. I must not understand that statement. I have a combiner box with a ground and lightning protection. Is this a problem? Here is a snippet from their manual:
4.4. Grounding
Battery grounding
The solar charger can be installed in a positive or in a negative grounded system.
Apply a single ground connection, preferably close to the battery, to prevent system issues or ground loops.
Chassis grounding
A separate ground path for the chassis ground is permitted because the chassis is isolated from the positive and the negative terminals.
PV array grounding
The positive and negative of the PV array should not be grounded.
Ground the frame of the PV panels to reduce the impact of lightning.
Do not connect the solar charger to a grounded PV array. Only one ground connection is allowed, and this should be near the battery.
4.4. Grounding
Battery grounding
Chassis grounding
PV array grounding
