I'll run an experiment. I like experiments. I'll put my calibrated and traceable Fluke meter on the output of the inverter and graph its output until one of the anomalies occurs and see if there's actually anything there.
I ran the test over the past 24 hours and caught one anomaly on Solar Assistant where my output apparently dropped to zero. As you can see in the Fluke display, that never happened. Seeing as I was out in the shop working at this time, I would have noticed if everything went dead. I've communicated all of this to Pierre at Solar Assistant. He's aware of the issue and is addressing it now. He's asked that I try the next beta release where he hopes to have it fixed and I will do that when it's available. Keeping in mind that Solar Assistant can also send data to the inverter, that's the reason why I suggested disconnecting the USB cable from your inverter to see if your fault code 61 goes away.I have two 12kw running both using the same pi model and inverter 1 it runs perfect. It never does any quick restarts and the data is totally stable no odd fluctuations. I have no pv or grid on either one as well.
