Zwy
Solar Wizard
That is part of the reason I decided to go with 2 LV6548's instead of the GW 12Kw unit. If I decided to increase PV capacity and/or battery bank, the 2 LV6548's could handle more PV instead of being already maxed out.I had the DVM (150vdc PV max) version of this inverter with ~9.5kw of panels. It outputted 120A to my (14s leaf based) battery at any voltage it was at from the PV charge controllers. So if the battery was at 55V, it was putting out 55V*120A=6.6KW. One time I charged it over 58V and I saw the 7000W at 58V or so.
I ended up with a second small all-in-one inverter just to put some of the panels on and also to act as a AC charger from a small generator if I needed to.
