I am looking at getting a mini split for my RV, similar to this. Would it work with the Growatt 24v 6kW all in one? https://www.amazon.com/dp/B07QR1CK2...aWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1
I will contact them, but to confirm............ you think they will work together?COOPER&HUNTER | Ductless mini split systems, air conditioners | 404
Ductless mini split systems, air conditioners - COOPER&HUNTER, HVAC, cooling and heating equipment. | +1-786-953-6706cooperandhunter.us
Page 16
It appears you only connect L1, L2 (240V) and G to the outdoor unit and L1 and N (120V) to the indoor unit.
I would contact them to confirm. It's really not clear on their literature, but I believe the wiring diagram supports the above conclusion.
Thank you so much. And this will work with most batteries and solar panels? Or do you have suggestions on those for this system?I do. They are a product for North America with a 60Hz frequency. The L1 and L2 in the outdoor unit wiring and the L1 and N in the indoor unit strongly indicate they are intended to be powered by 120/240VAC split phase power in North America.
Ok, I for sure will need more education. And a dictionary lol. I thought this "all in one" growatt was an inverter and charge controllerThey key component will be an inverter capable of split phase 120/240V operation. Many just operate in 120V mode. Given the relatively low power consumption of the unit (21000BTU/21.5SEER = 976W), it shouldn't take much. Important to get typical run currents and peak currents from the manufacturer to have when you are selecting your inverter.
Solar panels power the solar charge controller, which charges the batteries. The batteries then power the inverter, which powers the minisplit:
Panels --->Charge Controller --->Batteries --->inverter --->mini split
Once you have clear picture of what the mini-split needs from a power perspective, you can begin to select your components. Step 1 is defining the loads. You're not quite there yet.
Ok thank you! I am also considering this one https://www.ebay.com/itm/Special-48...949694?hash=item48e4c7e07e:g:CLQAAOSwc65etO8~ The seller says it will work with the mini split.......... he says both will work but I guess this 2nd one has more power being a 48V rather then 24V. I am a total newbie and intimidated by the idea of killing myself with a 48V lol.It is, but you may find that it might not meet your requirements. Even with all-in-one units, the overall concept is the same in terms of how they work.
