Hello,
I'm new to this so there's a large probability I probably screwed up, but anyway here's my question.
I have the Growatt 24v 3000w all in one, and I just hooked it up to 2 12v SOK batteries in series. I have the AC output going through a breaker, then feeding a GCFI outlet. The outlet works, but when I plugged in my outlet tester it is giving me the "hot/neutral" reversed code. I then tested the output terminals and the N terminal (which I have hooked up to the white wires) is the hot one, not the L terminal.
Any ideas as to what's going on? Are the terminals mis labeled?
