Mrgulabull
- Jul 9, 2020
- 26
I've just finished a test setup using 2 growatt 3000tl LVM 48v all in one systems. I don't see any explanation on the functionality when wiring these two systems for parallel single phase operation. My assumption was that the AC load would be split between the systems in this configuration, but a quick test using the AC output from one Growatt does not show any load on the second Growatt.
Have I misunderstood the definition of Parallel Single phase? If so, what would be the purpose of paralleling the two growatts in a single phase application? First build, so please excuse my naivety.
Also, perhaps related to the parallel connection, but the units cannot have "power saving mode" enabled when paralleled. Changing the setting results in that setting switching back to disabled after a moment.
