Does anyone know if it is possible to set the max AC input current on a 48v Growatt 3000TL LVM-ES?
Right now I have 2x Growatt 3000TL LVM-ES running split phase 240v. For cloudy days, I have a 7500w generator to keep the batteries charged. For the most part, this is working great. I can even max out the Growatt's charging capacity at 40A each (at battery voltage). The problem is, I cannot find a setting to limit the overall draw on the generator. If I set it to charge the battery at max amperage and then use the microwave, toaster oven, etc., it tries to pull that from the generator too and overloads it, tripping the breaker.
Seems like an obvious setting to have on the Growatt but I can't find it anywhere. Am I overlooking something?
I tried a lot of settings including setting the AC output priority to SBU (solar > battery > utility) but that seemed to completely ignore the generator, not even letting it charge the battery.
I see setting 11 allows me to set the max input to use for charging the battery.
