I have 3x Growatt 48V SPF 3000TL LVM connected to 3 phase
1 Inverter for each phase.
Connected also are 6x growatt Ark 2.5L-A1 Batteries
PV System 12x 380Wp pannels
The system seems to work well when we got sun and the batteries are charged just fine.
But as soon as the system goes into battery mode, it seems something happens.
The Inverters would just restart. Output goes to 0, and then after about 30 seconds or so it comes back on.
There are no fault codes, no warning codes or anything so make investigating this easier.
If we use Grid Bypass (UTI 01) to run the house through the inverters also it works fine.
Some of the settings
01- SBU (Output source priority)
03 - APL (AC input voltage range)
05- LI (Battery Type)
08 - 120V (output voltage)
09 - 50Hz (output frequency)
12 - 50% (voltage point back to utility source)
13 - 95% (voltage point back to battery mode)
Video of the Inverters on Bat. First but failing and dropping to Util and then back to battery.
