Hello,
I am from Lebanon , and due to severe power outages in my country , i installed a growatt spf 5000 es with a lifepo4 Nruit 10.24 kw, to be charged from utility/grid (4h/24 per day, i didn't install PV yet).
So far so good, but whenever i set the battery type as LI (setting#5) it communicates normally with the battery BMS and i get SOC%, but i can't set the AC charging limit and the maximum charging limit. So i am forced to select USER in setting #5 (but i don't get SOC accurate percentage).
Is there a way i can edit the charging maximum current and the AC maximum charging current while selecting the battery type as LI ?
Thank you.
Thank you.
