Dear all,
My Low DC cut-off voltage is resetting and allowing only 42 V. This is a new situation. So not sure what is going on. The settings for the key parameters are:
1 Output source priority: To configure load power source priority– SUB
2 Maximum charging current: – 80A
5 Battery type – USE not USE2
11 Maximum utility charging current – 30A
14 Charger source priority: To configure charger source priority– SNU
19 C.V. charging voltage. – 56.4V
20 Floating charging voltage – 54V
21 – Low DC cut-off voltage 42V
#21 can be set to 47V if #5 is changed from USE. But I had successfully used USE and 42V as Low DC cut off.
I would really appreciate some feedback from people using USE and have Low DC cut off set to their preferred voltage please share your parameters. I believe USE has been the recommended setting for Battery Type for Growatt not using non BMS batteries.
My installation:
I have 2 Growatt 5000 ES installed in Parallel with 2 x Blue Carbon 48V 200Ah Lithium Battery Pack For Solar Home System. PVs are Mono 10 x 550W. 5 panels each in series to each Inverter. Priority is set to Solar, Utility and Battery.
My installation:
