Dear Sirs,
I bought my inverter growatt 5000es 48v from 27/05/2022 connected to 4 tubular battaries 200amp
The system was working amazing no problem at that time i didnt install solar panels yet. I was charging my batt from the our bldg. Generator and from the grid in case the Edl electrcity came.
Last week i installed 8 solar panel 655 watt candian solar and we installed a ground connected to 3 electrods in the ground and with all the needed dc and ac accessories surg arrestor pv breaker ac breaker and battery breaker.
The system is working well until yesterday i starting getting fault 08 only when the electrcity from the EDl goes on to the inverter am not facing any problem with the solar geting around 16 amp from solar during day and 2 or 3 amp at night. The problem is when the edl electrcity passes through the inverter it gives 08 fault and everyting turns off.
Anyone facing this problem i really need your help
Thanks and best Regards
