List of items i use for my instalation
-Inverter Growatt 5000es from Signature Solar
-Autotransformer Growatt (prepurchase 1 month ago from signature, still waiting for it).
-16 Cells LF280k from Doncan
-Riden RD6024w with 1000 watts psu (have a special port for charge lithium battery, it have a relay that cut the charge, you can config the cutoff -amp).
-Digital Torque Adapter 3/8" Drive | Audible Alert
-Scotch® Rubber Splicing Tape 23
-NTE Electronics 25W030 (resistor for charge caps of the inverter before connecting the battery)
-100Pcs 22-16 Gauge Insulated Ring Terminals Electrical Wire Crimp Connectors (M6, Red) (for the BMS)
-TEMCo Hammer Lug Crimper Tool V2 with holes for bench mounting (Crimps Battery and Welding cables 8 AWG TO 4/0 Wire Gauge) (LOVE IT)
-Jokari 10270 Secura Cable Stripping Knife for All Standard Round Cables, No. 27, 13.2cm L x 2.9cm W x 3.5cm H
-10PCS 1/0AWG -1/4''Stud Heavy Duty Copper Terminals Battery Cable Crimp Lugs M6 (Inverter ports are M6 and the cells are M6)
-10PCS 1/0AWG - 5/16''Stud Heavy Duty Copper Terminals Battery Cable Crimp Lugs M8
-Single Stud Battery Junction Posts, Heavy Duty Power and Ground Junction Block Power Distribution Studs Terminal Kit, Pack of 2 M8
-Klein Tools 3005CR Wire Crimper Tool, Ratcheting Insulated Terminal Crimper for 10 to 22 AWG Wire
-EWCS 1/0 Gauge Premium Extra Flexible Welding Cable 600 Volt - Combo Pack - Black+Red - 10 Feet of Each - Made in the USAç
-Klein Tools 11063W Wire Cutter / Wire Stripper, Heavy Duty Automatic Wire Stripper Tool for 8-20 AWG Solid and 10-22 AWG
-DC12V 24V 48V 250A Moulded Case Circuit Breaker Battery 250A MCCB Car Charging Pile Protector TAIXI (for the battery)
-180W Electronic Lithium Load 12V Vehicle Battery Test Capacity Monitor Discharge Power Supply Checker + Tester BOX (you can test battery and PSUs)
-BMS JK-B2A24S20P with LCD screen
Right now i am balancing 8 cells with the Riden Psu, what i want to know what the next thing to do, test each cell or just test some? i have this for make the test:
