So I finally got my system set up and wanted to test a load that was around 18 amps. It is a computer server rack. I had the Growatt in Util mode, and I was getting 111-115 voltage, and the inverter wouldn't handle the load. It kept tripping and restarting the computer equipment constantly. The load is only around 2300 watts. I've tried to start things up slowly thinking it might be the surge power, but no luck. I have a 20 amp breaker on the Panel that's connected to the inverter, that hasn't tripped. When AC input is hooked up I am getting a warning code 10 which stays on. I've also gotten a fault code 52 on the unit too. When I place the unit into SBU mode, it's outputting 240v, onto a single wire (Load from inverter to Panel). Which won't work since I need to have 120. What am I missing? I've attached a photo of the setup I have. The blue wire is the neutral. I've confirmed the grounds are bonded from input and output, additionally PV is not hooked up currently. I am waiting to install that once I get the AC setup going.
I am in the US and this is all within the same building
Thanks
Thanks
