Hi. I bought two growatt 5000ES inverters. They both come with the wires required for parallel operation. I followed the instructions and connected them and programmed them to parallel single phase (one is a master and one is a slave). All is working fine (since yesterday). However, ever since I set them up, i have had an 'uneasy' feeling. Because the outputs are joined and the inverters sync their waveform, frequency...etc... so as long as all is working, all is good.... however, what happens if they lose connection between them??? Eg. A connection cable comes loose.... what happens? Do their outputs become out of sync??? If so this could be catastrophic... having two phases connected together.... it is in essence a short circuit.... does anyone know how safe it is to run inverters in parallel (with communication connections between the inverters)? Has anyone had any problems? Also, a question specific to the growatt spf5000es: if they are set up to run in parallel in single phase mode, and if for some reason one turns off or is turned off (or both of them), when turned back on will they still automatically be paired and work synced in parallel or do I have to reconfigure them to run in parallel? Any info would be much appreciated. Thank you.
